Uploading results to wahoo gps computer after a 4dp and half monty test
Do you think it will ever be possible to upload the results of 4dp and half monty fitness tests direct to wahoo’s fitness computers?
Why do you want to have these numbers in your Elemnt computer ?
Likely to update the FTP, which is used by the head unit to calculate the metrics for a ride recorded by said head unit. One less thinv to manually update when a new FTP is recorded.
I use ZWOFactory to build some structured workouts, that I upload to my Elemnt Bolt, and the FTP is set in the app building the workouts. I think when the workouts come from Training Peaks, it’s also the same, you have to set your FTP in TP, and then it calculate the different power values of the intervals.
